enable/disable horn honk when locking doors
Old Apr 16, 2014 | 12:04 PM
Jigabop's Avatar
Jigabop
Default enable/disable horn honk when locking doors
Just thought I would pass this along since I figured out how to do it yesterday. This process should work on all second gens (or at least late model second gens with factory keyless entry) gas and diesel alike. should also work on dakotas and durangos.
with door closed, put key in ignition and turn key to the "on" position without starting.
on the keyfob, hold down the "lock" button for 4 seconds, and then push and hold the "unlock" button while still holding down the "lock" button until you hear a chime. release both buttons, turn the key off, and you're done!
make sure NOT to hold down the lock button longer than 10 seconds before pushing the unlock button or the process will not work.
3rd/4th gen trucks have a similar process to enable/disable horn report on door lock, but instead of using the unlock button after the 4 second period, they use the panic button, otherwise the procedure is identical.
Old Apr 16, 2014 | 12:53 PM
Ham Bone's Avatar
Ham Bone
I had to do this years ago when i accidentally cut it off somehow.
Good info right here
Old Oct 20, 2023 | 09:46 AM
Dodgeguy06's Avatar
Dodgeguy06
Could not get this to work
