Stainless Steel Bolts
Old May 28, 2014 | 08:34 AM
renardk764's Avatar
renardk764
Default Stainless Steel Bolts
Are there any downsides to using stainless steel fasteners in place of the regular fasteners for timing covers, oil pan, accessory mounts, water pumps, etc?
Thanks!
Ken
Old May 28, 2014 | 09:10 AM
oxymoron29's Avatar
oxymoron29
Of equivalent grade, absolutely not. Stainless hardware is far superior in that they will not rust like plated steel will
Old May 28, 2014 | 01:54 PM
renardk764's Avatar
renardk764
Thanks!
Old May 28, 2014 | 07:37 PM
RDuck's Avatar
RDuck
Use anti seize.
Old May 28, 2014 | 10:49 PM
Ham Bone's Avatar
Ham Bone
Your wallet will feel the difference
Old May 29, 2014 | 06:42 AM
RDuck's Avatar
RDuck
Originally Posted by RDuck
Use anti seize.
That was a quick post.
I use Stainless Steel bolts quite often at work.
They are a pain. Grab a 3/8 bolt and nut, tighten them down with an air ratchet. Good luck getting them apart.
That goes for all Stainless nuts and bolts.
Most, and I mean 90%, need to be cut off.
I've found antiseize helps.
We use Stainless when bolting aluminum pieces together.
Other than that I avoid them.
I will use Stainless washers with a standard bolt on aluminum if they're sight unseen.
