A little help here
Old Aug 20, 2016 | 01:13 PM
Ramman18's Avatar
Ramman18
Only thing wrong I see is the TX plate.
Actually, I noticed the front tire leaning. Are you sure it's parked on perfectly flat surface? I've freaked myself out before when parking somewhere only to realize its the ground causing unusual results, and always up front. If you're convinced its not the ground, be sure to check the bearings/hubs for play then have ball joints inspected.
