My dodge build (in progreess)
Hey guys been a while since I've posted. I have the old dodge all torn apart and building it in the garage. Every body part is being changed, getting rid of all that rust ny junk, I've put chassis saver on over 3/4 of the frame so far, built a sweet stainless steel front bumper, getting rid of 5 lug axles, have 2 dana 60s with 410 gears going in and much more. I am running a 360 magnum and a NV 3500. The motor is out of a 1999 dodge 2500 and the NV 3500 is out of a 1995. The truck runs great but here is wear I need a little assistance. I don't know what to do about the computer. I'm running everything off of the 318 computer that is sct tuned. I have shorty headers on it and the plenum kit. My next purchase is gonna be an m1 intake. Just making sure people think it's really worth it? I'm not worried about low end power loss because Its 410 gears and 5 speed with the 360 so there's plenty of low end power haha. I look forward to posting and being on this site again and sharing info I have aswell
You can re-flash the PCM to run the 360. As it stands, it will probably work, but, in open loop (engine cold, regardless of throttle opening, or better than about 50% throttle, regardless of engine temp....) it's going to run lean. Now, dodge tended to run the engines a little rich anyway, so, you *might* be ok, but, if you get a lot of spark knock, I would be looking for a new tune right quick.
M1/Hughes Air Gap: Eliminates the plenum problem altogether.... yeah, you may lose a bit of low end torque, but, you are compensating for that with more cubes, and the shorty headers. The advantage you gain is better mid-range, and upper RPM power. Yes, it's a compromise, but, I think it is a worth while one. |
(Post 3325305)
The dealer should be able to reflash the PCM with a stock 360/manual trans tune, but, that will be the death-flash, and you really don't want it. (it sucks.)
Simply bumping the timing on the magnum engines isn't really a good idea. There is no knock sensor that the GM engines have.... (why dodge decided to do it that way is beyond me...) and they already have spark-knock issues... so, JUST bumping the timing is a really bad idea. Unless you like holes in your pistons...... Hemifever Tuning, Or Flyin' Ryan do great tunes for these trucks. Of course, you need the tuner as well. (the physical device for flashing the PCM.) so, not cheap..... |
Looks like some nice work you're putting into your truck! Nice!
