Press
Old Apr 1, 2007 | 08:21 PM
Dodge4x4810's Avatar
Dodge4x4810
Default Press
What kind of press do i use for the control arm bushings, ball joint press? If not, can i rent this press from an auto part store, or is it some specialty press that you have to buy? Also, can i use a ball joint press to press the bolts out, or will it just bend the bolts? I was going to cut them out with a sawzall, but i do not really know if i can get to the upper control arm bushing that it under the floorboard with the blade all the way, so i thought it just might be easier to press the bolts out if possible.
Thanks
Old Apr 2, 2007 | 04:11 AM
Dodge4x4810
Default RE: Press
No one?
Old Apr 2, 2007 | 10:40 AM
mopowar's Avatar
mopowar
Default RE: Press
I bought a set at Harbor Freight. Does ball and u joints.
http://www.harborfreight.com/cpi/cta...temnumber=4065
