Will 35s tires fit?
Old Apr 4, 2007 | 10:38 PM
stick1994's Avatar
stick1994
Default RE: Will 35s tires fit?
Tires fitting has alot of factors other than just "will they fit?". Width of the tire, back spacing of the wheel. And to me "rubbing" is minor not scraping the **** outta your tire. I have 5 inches of lift with 35's and can't turn all the way without hitting the outside of my fender.
Old Apr 4, 2007 | 11:16 PM
Cereal Killer's Avatar
Cereal Killer
ORIGINAL: dmdenike
you CAN fit 35's on a dodge with NO lift. You'll rub, but it can be done. I have 35's on mine. and theres NO lift
You have a 4X4 though too. For him it'd be more like if you put 38's on your truck.
Does it rub bad? I might do it if it doesn't.
Old Apr 4, 2007 | 11:40 PM
dmdenike's Avatar
dmdenike
it doesnt rub that bad....only at full lock
