Mis still there
Old Apr 5, 2007 | 10:47 PM
rk2003's Avatar
rk2003
Default Mis still there
I installed new plugs, cap ,rotor,wires, and coil.Motor still misses. Scanner say no Misfires and the injectors all check out with the scanner. The 360 just runs shi-y and shakesfrom idle to just under 2 grand then smooths outand seems to run fine. Sometime it is worse than others. I would really be thankful to get some feedback on this problem.
Old Apr 5, 2007 | 10:53 PM
mtrider's Avatar
mtrider
Default RE: Mis still there
Might want to check the compression,I've seen my share of burned valves at work.Hope this helps.
Old Apr 6, 2007 | 05:06 AM
hometheaterman's Avatar
hometheaterman
Cracked head? I've heard these heads are prone to cracking and will cause a missfire thats hard to track down. You didn't by any chance use the Autolite plugs did you? When I used them I had a slight missfire that I couldn't figure out so I decided to switch back to Champions and it cured it all up.
