door panel removal
Old Apr 8, 2007 | 01:19 PM
footballgonzo7's Avatar
footballgonzo7
Default door panel removal
I just bought my truck. its a 2000 ram 1500 and the fromt speakers are blown and i need to replace them could someone help me as to how to remove the door panels?
Old Apr 8, 2007 | 01:37 PM
TurboABA's Avatar
TurboABA
Default RE: door panel removal
They are held in with plastic clips.
There's also two screws in the grab handle.
I suggest you source out some of the plastic clips, as most of the time they like to break, or they are already damaged from someone priorly working on the door panels.
Once the screws are out of the door handle, start at a bottom corner and using a thick knife (almost like a butter knife) gently pry the door panel away from the door. Once you hear a snap, one clip has let go. Just repeat for the rest of the clips. There's probably about 4 or 5 clips on the bottom, 3 or 4 on the sides, and another 4 or so on top of the panel.
Take your time, and be as gentle as possible, and you'll keep the bracking of clips to a minimum.
Old Apr 8, 2007 | 02:40 PM
habeba86's Avatar
habeba86
https://dodgeforum.com/m_722530/mpag.../tm.htm#722530
Old Apr 8, 2007 | 04:27 PM
dhvaughan's Avatar
dhvaughan
couple more pics
https://dodgeforum.com/m_752221/tm.htm
