top gunz customz = garbage
Old Apr 10, 2007 | 02:26 AM
Nothing2Lose5150's Avatar
Nothing2Lose5150
Default top gunz customz = garbage
I've had the the 3inch top gunz customs rough country lift in my truck a little over a year spacer up front block in rear 1. the shock bushings went to **** in a month 2. the U bolts are about 2 feet long (exadrating obiously)and keep getting loose on me and i don't even do that much wheeling,i don't recomend it I should've done it right the first time 5" skyjacker this summer nuff said
Old Apr 10, 2007 | 02:50 AM
Works4Ford's Avatar
Works4Ford
Default RE: top gunz customz = garbage
Try Loctite on the U-bolts.
Old Apr 10, 2007 | 03:27 AM
20dodgeram01's Avatar
20dodgeram01
mines fine. just get new shocks. no big deal..
Old Apr 10, 2007 | 05:19 AM
stick1994's Avatar
stick1994
Don't you mean rough country's junk...not TGC? [sm=wootwoot.gif]
Old Apr 10, 2007 | 11:11 AM
Tani1500's Avatar
Tani1500
if you bought a **** country lift from TGC how is that there fault? its Rough countrys lift they just sell it. plus its the shocks your talking about so get new bushings. are they new shocks or your stock one? also are u serious about the u-bolts being long... they make them long on purpous and your suppost to cut them[8D] also you need to retorque the bolts at least 3 or 4 times... and locktight goes work too
Old Apr 10, 2007 | 12:52 PM
tdmopar59's Avatar
tdmopar59
yea i would reccomend using locktite and cut your u bolts and rough country is just a cheap way to lift your truck you get what you pay for
Old Apr 10, 2007 | 07:45 PM
jisthangin01's Avatar
jisthangin01
You can also double nut the ubolts.. It should lock the 1st nut in place.. and than cut the extra ubolt off
