lift help
Old Apr 10, 2007 | 07:12 PM
towguy2007's Avatar
towguy2007
Default lift help
i need help on figuring out what lift i should go with on my 1500 and what would be safe offroad spacers or coils think about 5.5 or 6 please help
Old Apr 10, 2007 | 07:36 PM
spaz_22's Avatar
spaz_22
Default RE: lift help
well..glad to hear you want it up in the air...but first you neeed to decide some things...first what size tires do you want to fit, with a 5.5 to 6 inch lift you can fit 35's no problem 37's are iffy...second, how much do you want to spend? if you are looking for the cheapest way to lift your truck 6 inches...you can get away with a 3 in body lift, and a 3 inch spacer kit (3 inch coil spacers front, 1.5 or 2" blocks in the rear) probably pretty close to 500 or 600 dollars if you install it yourself...but if your looking into a full supsension system your looking into close to 1500 dollars installing it yourselft..but if you ever do a 6 inch lift, and want to go alittle bigger you can install the body lift later and get that extra lift...it all depends on your budget really
