QUESTION!!!
Old Apr 10, 2007 | 09:34 PM
suprchgrs's Avatar
suprchgrs
Default QUESTION!!!
What are the signs to know when you must replace a front wheel bearing on a 4x4?
Old Apr 10, 2007 | 10:00 PM
Frye's Avatar
Frye
Default RE: QUESTION!!!
It will squeak like your brakes, but won't stop/start when brakes are applied. Or just go with every two years a whole new hub/bearing assembly, especially if you are 4WD. Jack your truck up and push on your wheel, if it wobbles, you know you need a new assembly. Check the balljoints/U joints as well. If you are gonna change one side, change the other.
Old Apr 10, 2007 | 11:38 PM
TMS Bill's Avatar
TMS Bill
Read this: https://dodgeforum.com/m_706631/tm.htm
