Brake Problems
Old Apr 15, 2007 | 03:05 AM
griffman6902's Avatar
griffman6902
Default Brake Problems
I have a 98 Dodge Ram Sport. I bought it about 6 months ago. Ever since I had it the rear brakes have been acting up. Occasionally I will barely put on the brakes and the rear brakes will slam on. If it on anything but a road they lock up and slide. It seems like it's something electrical just by the nature of things. I'm also not 100% certain that the ABS is working correctly, but I didn't bother with that because frankly I don't like ABS. The light for ABS isn't on. Any ideas are greatly appreciated.
Thanks,
Ross
Old Apr 15, 2007 | 03:09 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Brake Problems
sounds like they may be mis-adjusted. not too sure about the newer brakes systems though. I would stop into a brake shop for a free estimate...
Old Apr 15, 2007 | 08:50 AM
Crabman's Avatar
Crabman
I also hadthat problem, like many others, with the rear brakes locking up especially after it rained. I decided to do my rear brakes and install new wheel cylinders (https://dodgeforum.com/m_498851/tm.htm) at the same time.
There aren't enough O's in smoooth at how my brakes work now. Never had a lock up since. Found my old cylinders leaking a littlebut beyond that nothing very obvious. Not saying that the oversized wheel cylinder helped in the lock-up, just saying for others reading this, while you are in there and if you have a 2500/3500, consider the cylinderswap. The new shoes and turning the drums,really did the trick. I used NAPA brake shoes.
Good luck.
Old Apr 15, 2007 | 02:18 PM
griffman6902
So were the cylinders the problem or should I just go in and replace the shoes first and see if that heals things? (I'm kinda broke currently, haha)
Old Apr 16, 2007 | 09:53 PM
TMS Bill's Avatar
TMS Bill
You probably have contaminated brake linings. That's usually the reason for brakes "grabbing".
BTW ... the wheel cylinder upgrade isn't just for the 2500/3500 crowd.
