Some help please? Cat clogged? update
Old Apr 16, 2007 | 08:02 PM
Ram_Sport's Avatar
Ram_Sport
Default Some help please? Cat clogged? update
2 questions,
one, why does my truck all of a sudden groan under acceleration getting slightly rougher as it gets higher in rpm.
and lastly why do the rear brakes grab hard all of a sudden, like i can almost lock them super ez. they have been wet as i did some trail riding which submerged them couple times but idk why they still grabbing likethis..
Edit: Changed Subject Line
Old Apr 16, 2007 | 09:41 PM
Ram_Sport's Avatar
Ram_Sport
Default RE: Some help please?
the groan seems like something gear/tranny/tc related not power but drivetrain and im hopeing its just the engine working harder to turn the new tires
since a couple weeks back i have gotten a new brush guard along w/ some lights and 33" toyo open country a/t tires which btw are amazing
Old Apr 17, 2007 | 12:40 AM
TMS Bill's Avatar
TMS Bill
Grabbing brakes is an indication of contaminated linings ... pull a drum ... you might find a leak (axle or wheel cylinder) ... or you might just find a bunch of dirt. At any rate ... spray everything down with brake cleaner (top to bottom) to wash off any crap (air dry) ... do inside the drums, too. See if it helps.
Old Apr 17, 2007 | 02:41 PM
Ram_Sport's Avatar
Ram_Sport
on another note, i have no power on the highway and its getting worse, if i nail it at 65 it goes to 2nd gear and just screams it feels way weaker than a few days or so ago and its getting worse... suspecting the cat melted or pluged i tapped it w/ a hammer last night, nothing no rattle, would a fried cat do this whats up, help plzzz
Old Apr 17, 2007 | 09:16 PM
Ram_Sport's Avatar
Ram_Sport
well on the way back from college the truck lost prly all of its power, this got progressivly worse threw check engine light and for cylinder misfires there was extreme backpressure in the exhaust causing it to have almost 0 power couldnt go above 55 on I94 so i took it to the nearest autozone for the code pulls the misfires, my guess was my cat melted for some reason.. it started probably friday on the way back from spring break i noticed engine load and less power got slightly worse today took its final dive, getting the cat cleaned up tommorow and hopefully it will run better.
pulled the front o2 and it was exhausting out the bunghole like mad i figured usually it would continue its normal path and only puff thru slightly but it was like a big difference it was PUFF PUFF PUFF and so i hit the cat and i can hear a chunk bouncing around in there so..
for the brakes im gonna take your advice and clean the shoes and drum next time i get in there but the cat is urgent fix so thats first on the line, i didnt see any leakage or anything abnormal in there.
Old Apr 17, 2007 | 09:31 PM
TMS Bill's Avatar
TMS Bill
What do you mean ... "getting the cat cleaned up"? You mean replaced, right?
Old Apr 17, 2007 | 09:35 PM
Ram_Sport's Avatar
Ram_Sport
gutted, cleaned out, cut open emptied and welded shut again.
Old Apr 17, 2007 | 11:01 PM
TMS Bill's Avatar
TMS Bill
I so envy y'all ... no emissions inspections ... [:'(]
Old Apr 17, 2007 | 11:29 PM
QuadCab318's Avatar
QuadCab318
yeah
Old Apr 17, 2007 | 11:33 PM
96_59L's Avatar
96_59L
hey all im new and to answer the cat problem mine all the insides came loose and started to clog up and when I hit the gas on the highway it didnt want to move. I had to get a whole new cat. waste of 300 bucks.
