does a 42re have bands?
Old Apr 25, 2007 | 07:29 PM
jstnumber73's Avatar
jstnumber73
Default does a 42re have bands?
I have a 42 re and im going to change the filter/fluid. I dont know if i have to adjust the bands or not. One mechanic told me its just electronic and it has no bands. But ive seen on a whole bunch of websites that it has 2? A front and a rear. please help thanks.
Old Apr 25, 2007 | 07:39 PM
QuadCab318's Avatar
QuadCab318
Default RE: does a 42re have bands?
yes the 42re has two bands, yes you should adjust them
here are the adjustments
FRONT BAND
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 64).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 N·m (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and appropriate Torxâ„¢
socket.
(4) Back off front band adjusting screw 3 turns.
(5) Hold adjuster screw in position and tighten
locknut to 41 N·m (30 ft. lbs.) torque.
(6) Lower vehicle.
REAR BAND
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns
(Fig. 65). Be sure adjusting screw turns freely in
lever.
(4) Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque.
(5) Back off adjusting screw 4 turns.
(6) Hold adjusting screw in place and tighten locknut
to 34 N·m (25 ft. lbs.) torque.
Old Apr 25, 2007 | 07:45 PM
QuadCab318's Avatar
QuadCab318
there is more......
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 N·m (13 ft.
lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopar
t ATF +4, type 9602, fluid.
Old Apr 25, 2007 | 11:39 PM
ICEMAN_CH's Avatar
ICEMAN_CH
This is a dumb question but what are the bands for?
Old Apr 25, 2007 | 11:51 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
No way in hell is this guy a mechanic. If he is, then he's either A) incompetent, or B) untrained.
