PLEASE help ASAP!!!!
Old Apr 27, 2007 | 10:05 PM
asybra00's Avatar
asybra00
Default PLEASE help ASAP!!!!
I need new tires for my dodge ram 1500 4x2 not the 4x4 and i have a guy that will sell me a set of pro comp tires and rims that are 33's for $500 but my only concern is the fact that they are 33's and i have 265/75/16 on there right now does anyone know off the top of there head if i will have the wheel well clearence in the front to put these on?? I measured with the good ol' tape measure and it looks like it will be close. I might end up rubbing on the inner wheel wells up front but i could just cut the front bumpre cover a little bit i think?? Please give me some thoughts asap im supposed to meet him in a few hours. I know that if I had the 4x4 it would probably work but the 4x2 sits a little lower up front so i just want everyone elses opinion so i dont go and waste my time if they wont fit. Thanks everyone.
Old Apr 27, 2007 | 11:01 PM
stick1994's Avatar
stick1994
Default RE: PLEASE help ASAP!!!!
what's the width on those tires? are you gonna run them on stock rims? You can always get spacers and a body lift. But thats adding about $250 more to spend.
Old Apr 27, 2007 | 11:34 PM
asybra00's Avatar
asybra00
hey guys this is the link for the rims that i was lookin at he wants 500 for rims and tires but he might take 400 im not sure just want to make sure they would fit without an imediate body lift http://honolulu.craigslist.org/oah/pts/319699420.html
Old Apr 28, 2007 | 01:58 AM
dhvaughan's Avatar
dhvaughan
i think you're going to have a rubbing problem. i would not recommend getting them unless you can put them on and drive around the yard and test them. turn back and forth to full lock and see if they rub. also, picture the bed loaded down and sagging in the rear and look for rubbing there too. the rear sag could be helped with helper springs.
