4X4problems
Old May 1, 2007 | 03:22 AM
calm_cousins's Avatar
calm_cousins
Default 4X4problems
the 4 wheel drive on my 2001 Ram won't stay locked in, it will hold for a bit but then wil dis-enguage
and try to re-enguage and then dis-enguage. it is not making any aweful noises or anything like that and you can feel it pulling when it is in 4 high. Hope sombody has had a similar problem and can tell me what to fix
[align=left] [/align]
Old May 1, 2007 | 05:26 AM
FixOrRepairDaily7638's Avatar
Default RE: 4X4problems
check your vacume lines and make sure you look at the linkage to your transfer case the linkage bar may be bent. i had both of theese problems on mine.
Old May 1, 2007 | 07:52 AM
Crabman's Avatar
Crabman
I agree the vacuum lines could be cracked or the diaphram in the vacuum solenoid could have a hole in it. Both jobs fairly easy. Mine was the diaphramhole.
Old May 1, 2007 | 04:04 PM
hkspwrsche's Avatar
hkspwrsche
Someone said in another thread that the vacuum line assy was $30 from the dealer- maybe someone else can enlighten us on the vacuum diaphram price$?
Old May 1, 2007 | 10:16 PM
Crabman's Avatar
Crabman
I don't believe you can just replace the diaphram alone. You have to change the whole unit.
Old May 1, 2007 | 11:04 PM
TMS Bill's Avatar
TMS Bill
This sounds more like a slow leak in the vacuum system than a messed up diaphragm. Does the throttle position have any effect on the problem? IIRC ... there's a check valve on one of the lines above the xfer case. Might be a good place to start.
http://www.dodgeram.org/tech/repair/..._engagment.htm
