Need exhuast coupler size for rear of Cat.Converter
Old May 3, 2007 | 02:03 PM
hkspwrsche's Avatar
hkspwrsche
Default Need exhuast coupler size for rear of Cat.Converter
Gonna gut the cat the easy way only cutting it open from the rear. What size coupler is it? 2 1/4 od on the fact pipe?
Old May 3, 2007 | 02:04 PM
hkspwrsche's Avatar
hkspwrsche
Default RE: Need exhuast coupler size for rear of Cat.Converter
anyone have a pic of the coupler you used? straight sleeve that fits out size on both sides or inside or combo?
Old May 3, 2007 | 03:17 PM
FixOrRepairDaily7638's Avatar
auto zone caryies them and its 21/2 inch pipe comeiong out.
Old May 3, 2007 | 06:46 PM
hkspwrsche's Avatar
hkspwrsche
did you use a coupler that fits around the outside or inside?
Old May 4, 2007 | 02:20 PM
the outside it is about as close to a perfect fit as you will get. you might need to tapp it on with a hammer because it is a little tight.
