94-95 pcm
I know for you 96+ guys torque management can be removed from the pcm via B&G flash. Since this flash is not available for us OBD1 guys (94-95) is there anything that can remove this from our pcm's? Or better yet, do 94-95's even have this "torque management"?
I don't think obdI is flashable.
Go here:
http://www.moparpart.com/dps_index.html
and down in the left hand cornerplug inthe part# p5249546. That's thepart # for the Mopar performance pcm for the 94-95 5.9l Ram.94-95 5.2lRam is p5249545.I think that is the best you'll do with obdI short of a stand alone.
edit:
** Emissions exempt in California, Massachusetts and New York only. Requires the use of premium unleaded fuels (92+ octane). 1998 and later models require VIN and Mileage encoding by a DaimlerChrysler franchised dealer. Not recommended for towing
Go here:
edit:
Also, I'm not real sure 95's had torque management, but, if they did, I'm not sure that the Mopar pcm will remove it. I know Silver Dodge was running a Mopar pcm for a while. Maybe he can say.
