O2 sensor or TPS
Old May 7, 2007 | 12:48 PM
BradBeyer's Avatar
BradBeyer
Default O2 sensor or TPS
I am having a problem with the truck dying after about 200 to 250 miles (all info in sig). I have to reset the PCM and then everything is fine again until the 200 or 250 mile mark. I know the PCM is relearning something butI have no CEL to tell me what it does not like. It only dies if I let off the gas and it is not all the time.
I have two theories and need to know which is more likely:
[ol][*]my o2 sensors have never been changed...just cleaned a couple of times...and I have 200,000 miles on the truck[*]the tps is shot and i need to get a new one[/ol]
I am not sure which it is or if it is either of them. ANY help would be awesome.
Brad
Old May 7, 2007 | 04:52 PM
BradBeyer's Avatar
BradBeyer
Default RE: HELP PLEASE
any ideas
Old May 8, 2007 | 12:44 PM
BradBeyer's Avatar
BradBeyer
Default RE: O2 sensor or TPS
Anyone?
Old May 8, 2007 | 02:34 PM
bander's Avatar
bander
I guess first would clean out the TB and make sure its not dirty. Check the gasket also on it.
Are there any codes being thrown out?
Old May 8, 2007 | 02:45 PM
BradBeyer's Avatar
BradBeyer
I have cleaned both O2 sensors and the TPS and it still has not fixed the problem.
There are no codes being thrown because the CEL is not coming on.
I have also changed spark plugs last week to autolite 3923...the old ones were pretty bad...electrodes (the part you gap...the arm)were white and pitted.
Brad
