leaning down
Old May 8, 2007 | 03:00 PM
addy4368's Avatar
addy4368
Default leaning down
my truck leans down on the passenger side in the frontabout 1.5 inches lower on the frontpassenger side, does this sound like a shock or a spring problem. thanks
Old May 8, 2007 | 03:01 PM
tdmopar59's Avatar
tdmopar59
Default RE: leaning down
most likely your shock climb under and as long as your coil looks like it is still solid and strong its gonna be a shock.
Old May 8, 2007 | 04:32 PM
spaz_22's Avatar
spaz_22
i'm guessing it's your spring because your shock does not support the weight of the vehicle, unless the shock is putting your suspension into a bind...which i doubt.Anyways springs are known to sag. but usually it's the driver side. Superlift has a 3/4 inch spacer that you can get from them that should level it out.
Old May 8, 2007 | 05:39 PM
IndyRamMan's Avatar
IndyRamMan
on that subject...how often should springs be replaced?
