Blew up the 3.9
Old May 10, 2007 | 12:56 AM
Travis2000's Avatar
Travis2000
Default Blew up the 3.9
I snapped the crank in my 2000 3.9l ram. I was about to rebuild when a friend mentioned he has a 5.2 out of a 94 with harness and pcm. What problems should I expect to run into with one being obd 2 and the other obd 1. I am missing the power from my old 94 318 since moving on to a 2000 3.9 standard trans. Suprisingly enough fuel mileage was the same between the two.
Old May 10, 2007 | 12:51 PM
froesen's Avatar
froesen
Default RE: Blew up the 3.9
If the 318 PCM was set up for an auto, may have to flash it for the stick. I realize in 94 it would have still been an RH, but there's still lockup/OD. Also the 94 would still have had EGR, probably just block that off. Can't think of anything else off the top, but i'm sure there'll be other issues.
