Running Hot, UPDATED: Solved!
Old Jun 30, 2011 | 08:49 AM
  #131
aim4squirrels's Avatar
aim4squirrels
Good luck to you brother. Head gaskets are a heck of a lot of tear down for no extra vroom-vroom.
Hopefully, I'll be digging into my engine for a cam swap in a few weeks.
Old Jun 30, 2011 | 08:53 AM
  #132
Annihilator_X9's Avatar
Annihilator_X9
Originally Posted by aim4squirrels
Did you ever happen to use a wire wheel to remove old head gasket material? I've heard of that causing micro defects in the deck and head surfaces that can cause an issue like what you appear to have.
If you do tear it down that far, check the heads and deck for trueness, perhaps your previous machinist was a bit lazy on the details.
Sucks you haven't licked this thing yet
I don't know what it's called, but a friend of mine had a plastic type brush that we used when doing my plenum. Hooked it up to a drill. Thing worked like a charm for removing old gasket and crust. Didn't even make a scratch in the metal surfaces.
Old Jun 30, 2011 | 10:49 AM
  #133
drewactual's Avatar
drewactual
dang man... at least you KNOW what it is now.. and if you're going that deep in the engine- don't ya think a sausage cam is in order? :-)
Old Jun 30, 2011 | 10:55 AM
  #134
Gary-L's Avatar
Gary-L
Veteran: Navy
I still think the IAT was part of the issue. After all, I've been driving in 100º+ heat for a couple of weeks and she's been better behaved.
I've been tempted to stroke it, but I doubt I'll do that. I'm thinking maybe going .010 over. I'll check wit the guy at the machine shop to see what he says. This time around, I won't be as rushed to get the engine built as I was when I did it the last time. I'm going to take care of that damned plenum one and for all by having the bottom plate welded to it for a nice, fool proof seal.
Old Jul 26, 2011 | 08:31 AM
  #135
Gary-L's Avatar
Gary-L
Veteran: Navy
OK, so it's going to be a while before I get around to tearing the engine down since I can live with a tiny, tiny, TINY head gasket leak. This past weekend, with outside temps in excess of 100º, my son and I drove 200+ miles, round trip, to pick up some VW parts from a retired VW mechanic. All went well with the truck staying around 198º. Yesterday, when I headed to work, the temp gauge wouldn't budge above 150º. While stopped at an intersection, I turned on the heat (FULL) and placed my hand in front of a vent. The air was was warm, but not impressive. So it looks like the Failsafe thermostat has decided to stick partway open or has failed.
Old Jul 26, 2011 | 08:35 AM
  #136
aim4squirrels
Never much cared fit the failsafe thermostat, it just looks too damned over-engineered.
If it's really tiny, you ever thought about checking the torque in the head bolts?
Old Jul 26, 2011 | 09:40 AM
  #137
Gary-L's Avatar
Gary-L
Veteran: Navy
I did within the first few thousand miles after the rebuild. After 4+ years, would it really make a difference?
Old Jul 26, 2011 | 11:56 AM
  #138
charlie1935's Avatar
charlie1935
That's the way a failsafe thermostat is supposed to fail, in the open position.
I had one too and it failed the same way.
Old Jul 26, 2011 | 11:58 AM
  #139
Gary-L's Avatar
Gary-L
Veteran: Navy
Thermostats are supposed to fail in the open position. It pisses me off that the damned thing costs too much and lasted about as long as a bag of heroin in Amy Winehouse's possession.
Old Jul 26, 2011 | 12:11 PM
  #140
J415's Avatar
J415
I use to be a hardcore supporter of failsafe's, but when I began to have overheating issue's, I bought an OE stealership stat and compared them. The OE stats open and closing tolerances were much tighter then the failsafe's. I run an OE stat now.
