Oil Pan Question
Old May 15, 2007 | 02:34 PM
robformus's Avatar
robformus
Default Oil Pan Question
I have a 1999 Ram QuadCab 1500 4X4 I want to drop the oil pan. I guess my question is can I do that without taking out the motor and leaving the front Axel in place. I was thinking I might have more room ifI place jack stands on the frame then removing the oil pan.
Old May 15, 2007 | 03:45 PM
hkspwrsche's Avatar
hkspwrsche
Default RE: Oil Pan Question
some people have slightly diff clearance for some reason. I did a search on replacing an oil pump which should include instructions. some people have had to remove the starter. oil pump search:
https://dodgeforum.com/searchpro.asp...p;timefilter=0
Good luck
Old May 16, 2007 | 01:47 AM
dhvaughan's Avatar
dhvaughan
my 01/5.2 came out easy with no clearence problems on cross member, no engine jackup, etc. i did remove the starter and flex plate dust cover as described below. i wish i'd spent some time trying to get the oil pan off w/o removing all that stuff, because removing the starter is a pain.
getting oil pan off is a one man job. putting it back on and keeping gasket from slipping off took 4 hands. someone suggested tying the gasket in place w/some string through the bolt holes, then clipping it loose as you put the bolts in. that would probably work.
http://www.pavementsucks.com/tech/rearmain.php
Old May 16, 2007 | 10:11 AM
robformus's Avatar
robformus
Thanks dhvaughan that was a very helpful link...
