Front-end Click
Old May 18, 2007 | 11:54 PM
Aubrey's Avatar
Aubrey
Default Front-end Click
I have a clicking in the front end that sounds similar to when a CV joint goes out on a Honda. It's just not as loud or clunky sounding. It doesn't really do it so much driving straight unless I'm on the brakes. But it does do it in corners and especially when pulling into a parking space. Is this a u-joint going out? or something worse lurking? - thanks
Old May 19, 2007 | 11:32 AM
Tarner's Avatar
Tarner
Default RE: Front-end Click
U-Joint, tie rod, track bar,
Get under the front of the truck and have someone turn the steering wheel back and forth. Watch you tie rod ends and you track bar end for play. I had the same thing going on with my truck a couple of times. One time it was the track bar and the other time it was a tie rod end.
