headlight removal
Old May 24, 2007 | 02:26 AM
IndyRamMan's Avatar
IndyRamMan
Default headlight removal
Either its too late to see, or im just being lazy tonight, take your pic, but how do you remove the headlights.
Old May 24, 2007 | 11:58 PM
mikecjn's Avatar
mikecjn
Default RE: headlight removal
I have the 2000 Sport and I need to pull my drivers side out because my brother in law stripped out the torx head on the adjustment screw.
I looked it up in the manual from the "Merry Christmas" thread and it has you lowering the front bumper to access some of the bolts. Looks like a pain in the *** and I just haven't gotten around to doing it yet but now that the weather is warming up I will do it withen the next week or two.
Hopefully I am way off base here and read the book wrong and it isn't that involved but I ain't looking forward to it.
Old May 25, 2007 | 10:05 PM
thegr8schlotzky's Avatar
thegr8schlotzky
I had to remove the to trim piece on the front bumper, other than that, my arms were small enough to fit in and get to the bolts that are on the bottom of the headlights, the other two are quite simple, one is straight from the front on the inside of the headlight and the other is under the headlight on the outside, you can see the bolt between the gap of the bumper and headlight. Once those three are out, just pull (decently hard) because there is a push-in type scew on the very back that pops out when you pull. Good luck.
Old May 26, 2007 | 04:31 PM
mikecjn's Avatar
mikecjn
Was yours the sport model with the plastic front end or the standard front end? I think having the sport front end is what makes it tough to get at.
