injector?
Old May 24, 2007 | 08:59 PM
94 red ram's Avatar
94 red ram
Default injector?
i beleave my injector is taking a crap all the other plugs are fine but i pulled all the plugs and 8 looks really rich, and i just did a intake gasket, so its not oil ,so is there any other injectors i can use from anyother cars with the same injectors
Old May 24, 2007 | 10:08 PM
dhvaughan's Avatar
dhvaughan
Default RE: injector?
i don't know the answer to your question, but you could swap #1 and #8 injectors and see if the plug problem moves.
Old May 25, 2007 | 10:30 PM
94 red ram's Avatar
94 red ram
i was in a rush when i wote it, what i am asking is there another injector from a diff year/model i can get one from because our junkyard doesnt have any rams but i have an jeep injector when i did the engine swap i saved some of them, but i went to the parts store and the guy said the # were diff,beween theram and jeep and alsobecause my motor i got was out of a jeep, just asking but and my iac is messed up i know theres a way to clean it
Old May 25, 2007 | 11:55 PM
mopowar's Avatar
mopowar
Do a search on here for something like 'stock injectors' by Hankl. I believe that all of the obdII injectors flow the same @ 23.2lb/hr. I would assume that the physical characteristics would be the same as well, though I could be wrong. If you have a junk yard in your area, check it out. You need only to take off the airbox, turn outtwo bolts, and pulla little clip to remove an injector to take with you.
Old May 27, 2007 | 05:01 PM
jisthangin01's Avatar
jisthangin01
Where are ya from? I changed all my injectors out with new a couple months ago, but i kept 5 or 6 of the old ones. The ones that werent dirty and still working. You should probably change the o-rings on it, but if ya wana pay for the shipping, ill send ya one. I kept em for the same reason your looking..incase i had one take a crap on me again lol.
