ticking
Old May 25, 2007 | 01:53 PM
topsites's Avatar
topsites
Default RE: ticking
First, always check to make sure you're not low on oil!
Also if your EGR valve is stuck, the engine will fire off like a diesel at higher rpm's (but not at lower).
This should be in the diagnostic codes, you can pull them by watching the flashes of the Check Engine light after you turn your Ignition ON off ON off ON
Old May 25, 2007 | 04:17 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: ticking
ORIGINAL: topsites
already checked and added oil. i may need to add more. Iv never heard of the egr fireing like a diesel. being a 96 i have 0bd2, so i just plug my scanner in the port. No codes, just a whine that i heard yesterday because it was about the only time i had the windows up and no radio on.
Old May 26, 2007 | 04:35 PM
Sirhilton17's Avatar
Sirhilton17
Default RE: ticking
PCV valve?
