Axle Shaft Nut Wont Budge
Old May 28, 2007 | 09:55 PM
lucas3397's Avatar
lucas3397
Default Axle Shaft Nut Wont Budge
I am in the process of changing myhub assembly because the bearing is going bad, but I cant get eh axle shaft castle nut off for nothing. I have tried everything. I let some penetrating oil set on it for awhile, then heated it up pretty good then used a about a 5ft cheater bar and still absolutely no movement at all. Anybody have any ideas?
Old May 29, 2007 | 01:35 AM
dhvaughan's Avatar
dhvaughan
Default RE: Axle Shaft Nut Wont Budge
do you have access to an impact wrench ? if not, you might take it to a local tire shop or garage, have it removed, oiled, put back on not quite so tight, and then take it back home and continue.
Old May 29, 2007 | 04:46 AM
superfluous's Avatar
superfluous
If you don't mind being kinda redneck, use a long breaker bar longer than the distance from nut to edge of tire, Place tool on nut, drive truck so tool contacts the ground and that should loosen the nut...
...or break something spectacularly. Try it at your own risk.
Old May 29, 2007 | 05:34 AM
xyzik's Avatar
xyzik
Here is a note from the haynes manual:
NOTE: On some models, the axle hub nut on the driver's side has a left hand threads (turn clockwise to loosen)
...but it does not say which models?
Old May 29, 2007 | 08:32 AM
froesen's Avatar
froesen
hmm...mine wasn't left thread, but it did have nasty lock-goo on it, my slightly-less redneck approach was a floor jack under the handle of the breaker bar...worked good.
Old May 29, 2007 | 09:59 AM
flintspirit's Avatar
flintspirit
Probably why the bearing is gone,if nut was put on too tight! Spray it down with pb blaster and let it sit over night then do the redneck trick!I've done the same trick with the crank balance bolt.
Old May 29, 2007 | 10:14 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: froesen
great idea !!!!
Old May 29, 2007 | 08:08 PM
lucas3397's Avatar
lucas3397
I never thought about any of those ideas. I guess I am on my way outside to try`em as soon as I get done typing this. Thanks for the info.
Old May 29, 2007 | 08:22 PM
lucas3397's Avatar
lucas3397
Okay I'm through with it. I tried the floor jack underneath it first since there is no tire on it and all it did was bend my Crafstmen ratchet thats about 2ft long that I bought yesterday just for this job. So im done with it. Its gettin put back together and going somewhere..
Old May 29, 2007 | 08:30 PM
Socha_62's Avatar
Socha_62
Get a bigger cheater bar,seriously. Try to get one that'll go over or fit into the 5ft one you had on there. Leverage is the way to go. Even if you have an impact gun I doubt you have one with enough ***** and a compressor with enough ***** to run it. You'll probably need a good 1000 ft/lb one if its that tight, and those take like 90 cfm
