ignition parts
Old May 29, 2007 | 05:46 PM
atc250r's Avatar
atc250r
Default ignition parts
I'm the original owner of a 97 1500 with a 360 and the truck has 155,000 miles. All regular maintenance has been done as scheduled except for ignition components (plug wires/caps, distributor cap and rotor).Would you guys change these outeven though thetruck seems to run fine?
Old May 29, 2007 | 06:02 PM
JoeC1981's Avatar
JoeC1981
Default RE: ignition parts
I would change them all. Get some good copper plugs, OE champions are good, and cap with brass terminals. I had to change mine at 80k. It started misfiring to the point of dropping a cyl when it rained out.
Old May 29, 2007 | 06:24 PM
WayneC's Avatar
WayneC
I've got 77K on my '01 and am going to do mine this weekend. It runs fine now but maint. sched. says 60K.
Old May 30, 2007 | 12:33 PM
atc250r's Avatar
atc250r
Spark plugs I've actually changed twice but I was referrring to the wires and distributor cap and rotor. They're all original.
Old May 30, 2007 | 03:35 PM
tdmopar59's Avatar
tdmopar59
i did a full tune up not to long ago and i reccomend doing it because even if you dont notice it running a little slugish doesnt mean its not... i went with champion copper plugs not even 2 bucks a piece NAPA cap and rotor about 15 bucks and then with wires just get a good quality wire around 8mm...
