burn outs
Old Jun 3, 2007 | 08:44 AM
clive's Avatar
clive
Default RE: burn outs
nice. like the lift. the only lift kits ive seen for a 94 is a 2 inch packer to level the front with the back
Old Jun 3, 2007 | 03:09 PM
JarheadX's Avatar
JarheadX
i got 33 inch mickey thompsons and i still do burnouts not even wanting too, i wish i didn't, i actually want to keep my tires
Old Jun 3, 2007 | 03:24 PM
Truck Ram ROD's Avatar
Truck Ram ROD
i have a V6 in my 94 and i can't get that thing to burn even in a puddle of wateri am not sure if it is supposed to burn but i have not done anything to the engine yet so maybe once i do some mods it will burn
Old Jun 3, 2007 | 03:31 PM
froesen's Avatar
froesen
my 98 318 can't do a proper burnout to save it's life if it's dry out, little bit of rain on the road and you gotta be real careful with the throttle (3.55, 265's, posi). can't wait to try the 4.56 gears and detroit with those dinky 265's before the 35" show up....there'll be some rubber, i'm sure. the 2500 rpm stall TC going in right now should help a little too...
Old Jun 3, 2007 | 04:36 PM
tdmopar59's Avatar
tdmopar59
ORIGINAL: clive
thats because it is 2wd... however your truck is definitely capapble of doing burnouts i have a 96 with the 318 and it does them no problem
Old Jun 3, 2007 | 06:20 PM
IndyRamMan's Avatar
IndyRamMan
360 mod.
Old Jun 3, 2007 | 09:46 PM
Moparkid032's Avatar
Moparkid032
stupid question..but this bigger tires you have..wouldnt be more unsafer to your rear etc to do burn outs??
Old Jun 3, 2007 | 10:07 PM
clive's Avatar
clive
Default RE: taken addvice
just ordered new air intake and throtal body spacer. cant wait
Old Jun 4, 2007 | 12:06 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Moparkid032
yes and no...the rear can only take so much, but the rear can take quite a bit. If you have plus one or 2 sizes approx, you should be set. The more rubber on the road (width) the harder it is to break traction, which means more torque builds up in the driveline before it does, along with the diameter being larger, its harder to turn the tires so torque again builds in the driveline. so basicly...no.
Old Jun 4, 2007 | 04:22 AM
shott8283's Avatar
shott8283
or should be able to do this..
http://videos.streetfire.net/video/9...27002aed93.htm
