piecing lift kit myself...
ok i bought my truck with a 3 inch suspension and 3 inch body lift on already..now eventualy i would like to go higher..so my question is can i combine my suspension lift that i have on now..and piece a new one together to use both suspension lifts?? ex i have blocks in the rear and coil spacer in the front..so could i actualy just put new leaf springs in the rear and a new coil up front to combine the two..or will i need anything else?? thanks
you can do an Add a leaf in the back or new springs. then u can get 2 or 3 inch coils to use with your spacers. then your gunna need to get control arm relocation brackets, new control arms. and drop brackets for the track bar and the sway bar. you can use shock tower emiminator brackets and use your stock shocks.
