Air Filter Replacement
Old Jun 13, 2007 | 01:02 AM
dusty_duster's Avatar
dusty_duster
Default Air Filter Replacement
OK, I'm a complete and total NOOB to Dodge Trucks. I'll admit that.
Anyways, I've got an '01 Ram 1500 with the 318. The air filter is filthy. I need to replace it. However, I can't figure out how to get the old one out! [&:] I tried unlocking the three clips on the front of the air box, but I couldn't lift the lid. Then, I loosened the worm gear clamp that held the air box to the throttle body. I could now lift up the lid just enough to see the old dirty filter, but I couldn't get it open enough to remove the old filter.
What am I doing wrong? Thanks in advance!
Old Jun 13, 2007 | 01:03 AM
psychogang's Avatar
psychogang
Default RE: Air Filter Replacement
you have to take the filter and everything completly out to open it up all the way. i took mine off plenty of times. and once it even came off completly when i raced someone.
Old Jun 13, 2007 | 01:05 AM
dusty_duster
OK, but how do you remove the air box? I loosened the clamp on the throttle body, but the box still wouldn't budge???
Old Jun 13, 2007 | 01:06 AM
psychogang's Avatar
psychogang
loosen it as much as possible. and spin it a little back and forth when taking it off. it should come off easy
