Check Engine Light Bulb/Gauge Cluster Question
Hello All,
Okay, I have an issue. The actual bulb for my check engine light is busted...This light is actually soldered to the gauge cluster. Can I replace this or do I order an entire gauge cluster set?
Thanks
edit -- actually it is a diode, I dont know why I posted bulb. That means it would have to be resordered on, thats saying everything else is fine (which it seems). My question is, can you order an entire gauge custer?
Thanks
Yes you can replace the cluster, but i'd have the bulb replced, it'd be cheaper.
Here's a cluster on ebay it's for a '98 which is different, but it's an idea. http://cgi.ebay.com/ebaymotors/98-DO...QQcmdZViewItem
Yea after looking into it, i am going to try to replace the diode myself, doesn't look too bad. I have one sitting in the 4WD section, which I don't use, so I am going to steal that one.
