Y pipe before the converter?
Old Jun 20, 2007 | 01:07 AM
kayakman's Avatar
kayakman
Default Y pipe before the converter?
I'm getting shocks installed tomorrow morning. I think the cat is starting to rattle, going to get the mechanic to check it out. I have called around on prices in a new converter, one shop saidthat they are cutting the old duel inlet/single outletunitand installing a Y pipe and then a single in/single out converter and what ever muffler you want,etc.
Have you guys ever heard of this for a single exhuast system and what do you think of this application.
1998 Dodge Ram Quad Cab 360 V8
Cheers Kayakman
Old Jun 20, 2007 | 02:10 AM
98redram's Avatar
98redram
Default RE: Y pipe before the converter?
i have a 98 ram with a 5.2.. when my cat got clogged i cut it out and had the y-pipe that ur talkin about put in and then jus put a flomaster 1 in 1 out dumped and i really like the way it sounds.. without the cat i lost some gas milage and some top end but really gained some on the low end.. i hope this helps u some!
Old Jun 20, 2007 | 07:06 AM
kayakman's Avatar
kayakman
98redram, thanks but not aloud to dump the catalytic converter.
Old Jul 12, 2007 | 05:09 AM
kent_08's Avatar
kent_08
Rattling of cat converter is an indication that the inside substrate is starting to break apart and it seems that your Dodge catalytic converter is overheated which could likely be the cause of the failure. This problem should be taken care of right away. If the substrate breaks down further it could plug the exhaust and could leave you stranded on the side of the road.... Anyway, I haven't heard of this single exhaust system before... But one thing is for sure, a dual exhaust is said produce far more horsepower than a single exhaust; however, the cat-back system would have to be a “true” dual exhaust in order to be able to produce such horsepower. That is, this is the way you want your exhaust to be... Good luck!!!
