seafoam?
Old Jun 20, 2007 | 02:40 AM
ricoram's Avatar
ricoram
Default seafoam?
what is it where do i get it and what does it do? thanks
Old Jun 20, 2007 | 03:58 AM
Ramman18's Avatar
Ramman18
Default RE: seafoam?
Check all of your auto parts stores. Napa usually has it and now Schucks has it. It's a white can with red cursive lettering. It's an old school engine carbon cleaner/ bug bomb. Meaning it will smoke all the bugs out of your yard. Take off the breather hose from the brake booster and slowly pour in half a can with the motor running. It will suck it into the intake. Then shut it off for 10-25 min or so and then start her up. It will clean carbon, oil, cats, bats, rats, bugs, and anything else gumming up your combustion chamber. It's good to change oil afterwards and possibly plugs if you had a lot of smoke/carbon burn off. Price is less than ten bucks.
Old Jun 20, 2007 | 12:00 PM
rtmorrisjr's Avatar
rtmorrisjr
Is this a good product for preventive maintnence or should you only do it if you have a problem? Also, i've heard to let it sit for 6-8 hours, is it dependant on how much seafoam you use?
Old Jun 20, 2007 | 01:48 PM
zique's Avatar
zique
I would say it's okay to use as "preventative maintenance, just not ALL the time. If you bought the truck used and you have quite a few miles, I'd probably use it to clean any crap that you don't know is in there. But I wouldn't do it, say, every oil change or you'll probably start blowing gaskets like crazy. Just my .02
Old Jun 20, 2007 | 01:52 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: zique
Thanks, i just bought the truck about a month ago w/ 95,000 on it. i think im going to give the seafoam a try.
Old Jun 20, 2007 | 05:52 PM
mopowar's Avatar
mopowar
I don't think you'll blow gaskets from using seafoam.
The more you get in there and the longer you let it sit (up to a point) the more effective it will be.
