I'm sure ya'll have answered this already, but how do you get the headlights off? Mine are yellow, and I don't to buy new ones. I already got the outside cleaned up, just need to get to the inside.
Raise hood and all bolts will be removed from front. I believe it is two on the grill side and one on the fender side. Some will be a tight fit, but just push down on the plastic bumper and use an extension.
Yup, three bolts, two on the actual headlight and one on the corner. Pull straight out, twisting back and forth may help a bit, but it comes out straight.
