Bed removal
Old Jun 21, 2007 | 04:32 AM
IndyRamMan's Avatar
IndyRamMan
Default Bed removal
How do I remove the bed from the frame, when I put it back on the frame, does it have to be aligned or does it bolt in only one way. (ie, with or w/o cams or shims) Also, whats your guestimate on how much the bed weighs? 1/2 ton, 1/4 ton?
Old Jun 21, 2007 | 05:03 AM
spaz_22's Avatar
spaz_22
Default RE: Bed removal
6 bolt's and the fuel filler assembly and it's off....take measurements of the gap between the bed and cab...i think mine were around 3/4 to 7/8 of an inch and to put it back onget the bolts started and push shimmy the bed around until it's lined up then tighten the bolts back down..i had to move mine up for the bodylift. the bolts - one on each side up front near the cab, 2 on each side in the rear, very close to each other and close to the bumper, you'll need an extension to go through the frame...as for weight..you've got me but i don't think it weighs more then 300 pounds or so
Old Jun 22, 2007 | 02:06 AM
Aubrey's Avatar
Aubrey
Don't forget to disconnect the wiring for your tail lights before you lift it!
Old Jun 22, 2007 | 02:14 AM
nhlbill's Avatar
nhlbill
Two guys can lift the bed off and set it on the ground. We do it all the time at my shop to install goosenecks and underbed 5w hitches.
Old Jun 22, 2007 | 03:10 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: nhlbill
so its really not a lot of weight?
basicly im looking to break 14's by dropping weight. I believe Iv dropped about a tenth or two with what iv removed so far, just hoping the bed would kick that extra 2 or so.
Old Jun 22, 2007 | 02:54 PM
rtmorrisjr's Avatar
rtmorrisjr
what are you going to put in the beds place? If you leave it off, i think, IMO, you will just spin the tires more.
Old Jun 22, 2007 | 03:18 PM
BLKbeast's Avatar
BLKbeast
^^hes right man... should proabably strap some sand bags to the frame
