Poor gas mileage despite rebuild and no engine codes
Old Jun 26, 2007 | 10:12 PM
colorado ram's Avatar
colorado ram
Default Poor gas mileage despite rebuild and no engine codes
Hello. I recently had my engine bored .030 and I rebuilt it and put it back in my truck. Ever since, then my gas mileage keeps getting worse. I have checked many things and it doesn't help. Any ideas?
Old Jun 26, 2007 | 11:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Poor gas mileage despite rebuild and no engine codes
What was your mileage before the rebuild, and what numbers are you getting now?
Old Jun 27, 2007 | 12:29 AM
Socha_62's Avatar
Socha_62
Could be things not related to the rebuild. Bad O2 sensors, clogged cat, dirty injectors/fuel system.
Run some high concentration of injector cleaner through the tank. Not to high though, don;t go overboard. Also run some Marvel Mystery Oil in the gas tank, not at the same time as injetor cleaner, and some MMO in the crank case.
Old Jun 27, 2007 | 02:50 AM
steve05ram360's Avatar
steve05ram360
also make sure your injector timing is set right. you'll need a scan tool to get it set so you might have to have a shop do it.
Old Jun 27, 2007 | 06:21 PM
colorado ram
The injectors are clean, they have been tested and all work 100%. The catalytic converter is not clogged. We replaced one oxygen sensor last night, after testing them. Parts store scan said it was bad. I guess we'll see after we hit the gas station a couple more times!
Thanks for your input! It's greatly appreciated!
Old Jun 27, 2007 | 06:26 PM
colorado ram
Before the rebuild, it was at least 280+ miles per tank. Recently, we've been averaging 250 miles per tank.
Old Jun 27, 2007 | 06:41 PM
steve05ram360
one thing comes to mind... is the tailpipe blacker than normal? it is a possiblity that your fuel pressure regulator has gone bad or is not working right. If the FP is high then it would explain why your mileage took a dump. it would seem pretty coinsidental that it happend during the rebuild. was the truck down long?
Old Jun 27, 2007 | 07:09 PM
WayneC's Avatar
WayneC
Wait a minute.
Before the rebuild you would get 280 / tank and now you get 250 / tank?
Assuming a 20-25 gal fill up; you're only talking about a 1-2 MPG difference. And thats after being bored? Did you expect it to go up?
Old Jun 29, 2007 | 04:58 PM
colorado ram
Well, of course we expected to get better mileage!!! We have gotten 420 miles to the tank on an out-of-state trip before!!! In fact, we only got 238 miles out of the last tank! The 318 (bored .030) in our other vehicle gets almost 11 miles to the gallon and it's got a carburetor! See why it doesn't make sense?
Since we had to replace the fuel pump last summer, I know the FPR is new. It took 6 weeks to actually complete the whole rebuild project (4-5 of those were spent waiting on the machine shop).
Old Jun 29, 2007 | 05:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: colorado ram
Bigger bore = more fuel usage.
