MAJOR FRAM OIL FILTER PROBLEM
Old Jun 30, 2007 | 12:35 AM
BostonRamGuy's Avatar
BostonRamGuy
Default MAJOR FRAM OIL FILTER PROBLEM
So had someburning coming from under the truck... Finally found out what it was, the "Easy Grip" black plastic on the fram oil filter was burning since on my 98 ram its so close to the pipes/header. If you are using this type of filter check it ASAP!!!
Old Jun 30, 2007 | 12:39 AM
White Ram's Avatar
White Ram
Default RE: MAJOR FRAM OIL FILTER PROBLEM
Stay away from FRAM filters!!! Some guy did a test (bobtheoilguy.com ?? or something like that). FRAM filters are the worst. I useBosch.
Old Jun 30, 2007 | 12:46 AM
dhvaughan's Avatar
dhvaughan
i used fram filters on my 76 chevy for 30 years and 260k miles. must not be too bad.
Old Jun 30, 2007 | 01:05 AM
DSM_Dan's Avatar
DSM_Dan
Bah, thats b/c its a chevy.
IMO Fram's are ****. I use OEM filters, or Napa gold's, made by Wix.
Old Jun 30, 2007 | 04:33 AM
dennisadhs's Avatar
dennisadhs
Talkin about frams i did my first oil change on a truck today. Used to do it all the time on my 96 maxima. Thought everything went good until i started it up. Oil started to POUR from the filter. Couldnt figure out what was happening until i took off the filter. Well the gasket from the old filter stuck to the truck and I couldnt see it so the new oil filter wouldnt screw in all the way. My fault but i thought i would share the lesson i learned today. Always check for the gasket!!!
Old Jun 30, 2007 | 11:01 AM
360Sport01's Avatar
360Sport01
i use mobil one oil and filter, best oil around and filter around.
Old Jun 30, 2007 | 11:09 AM
WesV's Avatar
WesV
Here, check out
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
This is a wonderful study and perfect arguement against Fram. I have always used Purolator Pure One or Wix gold filters.
