Leaking Master Cylinder
Old Jul 2, 2007 | 02:13 AM
Moparkid032's Avatar
Moparkid032
Default Leaking Master Cylinder
Well I noticed my master cylinder is leaking from one of its seals..so i am curious on how hard are they to repalce???
[IMG]local://upfiles/62831/9B008D39C71A477687ED97F167B0C499.jpg[/IMG]
Old Jul 2, 2007 | 04:03 AM
Aubrey's Avatar
Aubrey
Default RE: Leaking Master Cylinder
It's not that bad. Just gotta bleed it well and don't over tighten the hard lines. If I'm not mistaken, you can put in a m/c from a 2500 which has a larger bore = push more fluid = slightly better brakes.
Old Jul 2, 2007 | 10:13 AM
dhvaughan's Avatar
dhvaughan
looks like its just leaking from the seal between the reservoir and the master cyl. if you're having no other problems, you might try replacing those seals only. i've never done it, but i do see that most master cyl can be bought w/o the tank, so there must be an easy way.
Old Jul 2, 2007 | 05:57 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: Aubrey
Larger bore will give you a harder brake pedal, and less pedal travel. Smaller bore makes applying the brakes easier, but with a longer pedal travel.
The factory mc's are very easy to rebuild. You can buy the kit at any auto store.
Bleeding IS the key. There are a few procedures to brake bleeding with the antilock valves.
Good luck with your ride.
