Very Unusual Problem.
Old Jul 2, 2007 | 02:20 AM
Dodgeboy328's Avatar
Dodgeboy328
Default Very Unusual Problem.
Well I went for a drive today and noticed that I needed to refill my washer fluid tank. So when I got home I filled it up with water. When I got back in the truck I tested the washers and noticed that the passenger side window sprayer was not working. I guess it's clogged up some how. Later that day I went back out to the truck and noticed a big water spot under it. I figured it was the AC, but I decided to check it anyway. I got to looking and noticed that the bottom of the washer fluid tank had sprung a pretty bad leak. I've never heard of anyone having either of these problems, leave it to me I guess. How do I fix the sprayer and where would I buy a new washer fluid tank? God I want a new truck! It's little things like these that just **** me off.
Old Jul 2, 2007 | 04:41 AM
ryans590's Avatar
ryans590
Default RE: Very Unusual Problem.
well you probley got a little piece of gunp in the sprayer u could try cleaning it but prob just as easy to replace, as for the tank best bet is a wrecker
Old Jul 2, 2007 | 11:54 AM
WesV's Avatar
WesV
If you have access to an air compressor, remove the line coming from the pump to the nozzles, then with a rubber tip on a blow gun, blow air back from the nozzles through the tube so that anything that is lodged will blow right back out.
Old Jul 2, 2007 | 01:56 PM
dusty_duster's Avatar
dusty_duster
If you don't have a compressor, get one of those cans of compressed air used to clean computers.
Old Jul 3, 2007 | 07:35 PM
gillessd's Avatar
gillessd
eBay if you need one. I've had the hose pop off before...
Old Jul 3, 2007 | 08:08 PM
2001dodgeram1500's Avatar
2001dodgeram1500
go to a salvage yard.
