Buzzer Question..
Old Jul 2, 2007 | 02:42 PM
DodgeRAmPower's Avatar
DodgeRAmPower
Default Buzzer Question..
Anyone know what wire/ fuse to pull to stop the buzzer noise if you have your door open w/ the key in the ignition? just curious :-)
Old Jul 2, 2007 | 04:57 PM
ryans590's Avatar
ryans590
Default RE: Buzzer Question..
pull out the door pin and cut the wire, i dunno if it will stop the dome light from comming on thow
Old Jul 2, 2007 | 05:36 PM
RamManRiley's Avatar
RamManRiley
just install a switch inline with the door pin. kinda like with the crown vic police cars but they have a mod you can do which puts it in "dark mode".
Old Jul 2, 2007 | 05:45 PM
ryans590's Avatar
ryans590
yah every year i do up about 30 trucks for the conservation officers here and they all get front and rear kills or "dark mode" its not hard to do on any vehicle just a matter of finding the right wire
Old Jul 2, 2007 | 06:16 PM
Redneck2345's Avatar
Redneck2345
the buzzer is molded right in to the ignition switch, so I would guess if you pull the ignition fuse the buzzer would stop. That only leaves the problem of starting your truck without the ignition
Old Jul 2, 2007 | 09:43 PM
dhvaughan's Avatar
dhvaughan
https://dodgeforum.com/m_852343/tm.htm
Old Jul 2, 2007 | 09:46 PM
Tani1500's Avatar
Tani1500
i just let it buzzed and felt around under there until i found the damn box and the snipped away
kinda wish i only cut the wire for the door buzzer though. i kinda liked it when i buzzed when i left the headlights on.
Old Jul 3, 2007 | 12:00 AM
Pyromanaron's Avatar
Pyromanaron
Where's that box at, Tani? I found this thread right after I made a post on the same subject. whoops
Old Jul 3, 2007 | 12:03 AM
Tani1500's Avatar
Tani1500
mine was tucked back behind the fuse panel . its alittle black box about 4 inches long and 2 inches high
Old Jul 3, 2007 | 09:47 PM
Truck Ram ROD's Avatar
Truck Ram ROD
you should be able to unplug that buzzer box that what i did on mine and everything else still works plus if you wanna sell your truck you can plug it back in for the next guy but maybe they changed it later on but thats what i did on my 94
