33s or 35s?
ORIGINAL: ryans590
auchually you can get a 360 (5.9L) with ither a standerd or an auto, ive driven one and have saw may more
ORIGINAL: Cereal Killer
they only made a 360 in auto
ORIGINAL: ryans590
if you put that much lift you will have more than enough room for 35's, (just sayng) the 360 will be able to turn them better too (i only have a 318) standerd or auto?
ORIGINAL: silverghost01
my ram has 3inch blocks in back from the factory and sits 2inches lower in front so i thought replacing the 3inch in back with 4inch and 3inch spacers in front things would be pretty level still same as if i were to leave the back with the 3inch blocks and put 2inch spacers up front
yah spaz is right
i just went and looked at mine ( i coudent rember exactley what it was in there) and it has 3 in coil spacers in the front (with taller bump stops) and the rear has a 1 in block between the axe and factory block and an add-a-leaf and it sits piffictley level (you can auchually put a level on the box rails and it is between the lines provided im on level ground)
ORIGINAL: ryans590
unfortunatley yes.....stock gears (3.55) are not good with this set up i have, im in the prosess of getting 4.10, (just gotta convince "somome" to let me spend more on the truck)
Someone: "Do you really need that"
Me: "YES" (answer everytime)
Someone: "I doubt it"
Me: "Well, I'm going to get it"
Someone: "FINE"
Typical conversation in my house. Anyone else?
