need lift help
Old Jul 5, 2007 | 11:13 PM
974x4Ram's Avatar
974x4Ram
Default need lift help
ok guys im new here and i just got my truck its a 97 clubcab 1500 4x4 with the 360 and i want to know what i can do to clear 37s can i get blocks and coil spacers and a 3' body lift b/c i really dont have the money to spend on a suspension lift. anybodys input would help. thanks
Old Jul 6, 2007 | 10:20 AM
rtmorrisjr's Avatar
rtmorrisjr
Default RE: need lift help
try doing a search for lifts. There are a lot of topics in reguards to lifts. But i think that that set up will allow for 37. Not sure tho. Like i said try doing a search.
Old Jul 7, 2007 | 01:35 AM
spaz_22's Avatar
spaz_22
depends on the rims. but if you get a 3" bodylift, and a 3" spacer kit, you will probably have to cut a little out of your fenders to clear 37's. Also if your going to offroad it alot, it'll probably rub alot, but for street driving it'll probably be okay. Also this is going to put alot of stress on your axles. so be prepared to replace alot of parts. You will also need to look into regearing you axles..but if you don't have enough money for the "proper lift" i doubt you'll have enough money for the gears....it'll be sluggish.....but your axles are going to take a beating
Old Jul 7, 2007 | 04:33 AM
horatio102's Avatar
horatio102
So you want to half-*** the parts that connect your truck to your axles? Save up your money for a while and do it right.
