Ram Running Warm?
Old Jul 7, 2007 | 05:36 PM
tat2dhllblly's Avatar
tat2dhllblly
Default Ram Running Warm?
I have a 1996 4X4 club cab short bed3/4 heavy duty ramwith a 5.9 L engine. It has 120,893 miles on it but the engine only has 24,056 on it.
The problem is that I cannot run it with the AC on because it heats up, it does not overheat, it just gets alittle higher in the operating heat temp then I care for. It also does this when I do any towing. It also had the same problem with the old engine too.
Now my question is could I get the engine to run cooler by swithching the radiator and tranny cooler to a single unit and mounting a electric fan as a pusher in the front, and also change the fan clutch to a bigger one and upgrade my fan, and also change my thermostat from a 195 to a 160?
Would this do the trick? Or is there some other options?
Also would it benefit from mounting an oil cooling system too?
Thanks...........Bubba
Old Jul 7, 2007 | 09:10 PM
ryans590's Avatar
ryans590
Default RE: Ram Running Warm?
for t-stat i wouldent go any lower than 180, lots have gone to 180 with good luck
Old Jul 8, 2007 | 10:03 AM
sawtooth's Avatar
sawtooth
I've been fighting the same problem with my '96. 5.9, 1500. Replaced the 195 deg themostat with two different 180 deg units (Napa & Stant). Radiator was flushed twice & flow tested, fan clutch was replaced with one that is very stiff when hot.
The radiator shop has an infra-red device for measuring temperature. With my gage reading 220 the temperature at the input to the radiator was 180 while the output was reading 110 deg. Ordered a temp. sensor from NAPA (it's the one under the alternator on the passanger side of the thermostat housing) not much difference. Using a resistor dek-a-box, checked the gage : 985 ohms = 130 deg F. 170 ohms = 200 deg F. 65 ohms = 260 deg F.I attemped to calibrate the gage by inserting a 33 ohm resistor in series with the temp sensor. Monday I'll visit the radiator shop & verify that the input to the radiator is 180 deg F with my gage reading the same.
By the way I ordered an external fan from Summit last wednesday which hasn't arrived.
Old Jul 8, 2007 | 11:48 AM
varmintjcl's Avatar
varmintjcl
Me too, I began having this same hotissue last summer, but it has gotten worse this summer. Mines a 96 1500 2wd. Its especially noticeable while running the a/c & when towing. When the temp goes up over half I also get some pinging upon acceleration, but the funny thing is the temp reading seems to go down some when slowing down from highway speeds. I've been running a 160 stat for several years now & it never was an issue. I changed it out to a 195 & it just got hot faster soI changed it back to the 160.
Here's what I've done trying to correct it;
1-New radiator &hoses...no difference
2-Separated the tranny cooler from the radiator...no difference
3-Replaced the temp sending unit...no difference
4-Removed the cat..discovered it was hollow, put it back on with a Fastman sim..no difference
5-Replaced the muffler, ( had some cat material stuck inside)....no difference
6-New fan clutch(from NAPA)...no difference
Granted our temps have been 110 to 117 lately, but thats typical here in AZ& this only began in the last year.
I bought this truck new in 96 and have a few mods that have never caused any problems like this until last year.
mods are;
1- M-1 intake( had the factory machining ridges polished out before installing)
2-polished throttle body
3-Three inch singleexhaust from the cat back (had some cheap headers on, but they kept leaking, so I put back on the factory exhaustmanifolds)
4-Mopar performance computer
5-K & N air filter
6- changed rear from 3:55 to 4:10 suregrip.
I tried putting back the factory ECM, but it ran rough & the check engine engine light came on, soI think it went south.
So now I'm stuck not sure what to do next, thought of new water pump, but if I do that I'd like to go deeper & replace timing chain & advance the timing a little, but then with this issue maybe I should tear it down & do a rebuild.
If anyone has come up with an answer to this issue(I've notice several members here posting with this same problem) please let us know if you have solved it.
