Cam help?
I have a 2001 Ram 1500 Sport with a 5 speed, the only performance mods are a K&N CAI, MSD Wires, 3.5" flowmaster exhaust, Hypertech programmer, and an AirRaid Throttle body spacer. I have been thinking about putting a cam and MAYBE a set of heads on it but im not sure what will be a good combination that wont make the truck run like crap. I have looked at some Lunati cams but i think so far i like the mopar performance purple shaft cam (PN# 312P4120233). If anyone has any experience or any ideas Ill appreciate the help!
Assuming that you have a 5.9, KRC210x all the way. I ran a Hughes 1828 that sucked. There are alot of guys running the 210x that love it. If you have a 5.2 the KRC206x is a good choice. They are basically Comp grinds, but on a 110* instead of a 112*.
http://www.krcperformance.com/krc/in...&Itemid=26
For heads, the Hughes Iron heads are good. They flow nearly as well as the Eddy aluminum heads, are cheaper and will last longer. If you're going to run a cam, go with the 2.02's, and get atleast the stage 1 porting:
http://www.hughesengines.com/partDet...amp;eTypeID=10
Ive been thinking about taking the spacer off because with that intake i had to really wrestle with it to get it back on the throttle body and it rubs the top of the firewall....
Trending Topics
ORIGINAL: mopowar
Also, which spring kit should I get out of these three?
http://www.hughesengines.com/partDet...p?partID=10759
http://www.hughesengines.com/partDet...p?partID=10396
http://www.hughesengines.com/partDet...p?partID=10762
Thanks.
Nevermind, I started my own thread.
