WILL THESE WHEEL FIT? PICTURES
Hello, can you tell me if the bolt pattern from a 2001 Dodge Ram 1500 is the same as a 2005? Need to know if these will fit my 05 ram 1500 . I guess these came off a 2001 with the off road package and special 17 inch wheel.
Also a link to see them, they look like 5x5.5 but says will fit a 2000-01, I have the same pattern so I wanted to know if any of you have these on your newer rams.
http://www.factorywheels.com/wheels/AW2126.html
Thank you
[IMG]local://upfiles/31002/A0908964E23043BBA359C7A9DCD384C8.jpg[/IMG]
Thank you
they will fit the only thing u might have to change are the lug nuts depending if the are for the 3rd gen or the 2nd gens the 2nd gens use a 19 mm lug nut the 3rds use a bigger 21 mm i want to say so the only thin u might to change is the lug nuts depending on which year they came off of
On gen 2 if you look at the back of the wheel when mounted you see that the head of the tie-rod is justinside the wheel showing that a 15" won't fit.
Look closely at the back of your '05 wheeland see if anything would keep a smaller wheel from fitting.
Oh I didn't see where he had 17's already, thought he was dubbin
Trending Topics
oh, i see..i don't think there's any suspension difference between dodges with 20's and dodges that came with 17's from the factory...so he shouldn't really worry about them rubbing anything. As for the 15's on 2nd gens, you can't fit them on 99 and up models because of the dual piston calipers. Anyways, since the rims are the same bolt pattern they should bolt right up. My only convern is if the hub is large enough...see if you can get a measurement of each, and if it'll fit over your hub you'll be good to go
