posi or not ?
Old Jul 22, 2007 | 09:20 PM
rhaines00ram's Avatar
rhaines00ram
Default posi or not ?
Should'nt my truck have a posi rear end ? It will smoke the right rear tire but the left will not spin .
Its a 2000 ram 4x4 sport
Old Jul 22, 2007 | 10:15 PM
spaz_22's Avatar
spaz_22
Default RE: posi or not ?
look under the hood there should be a sticker that tells you some info about your truck like gear ratio and if it has an lsd. Also you can get a build sheet from the dealership. But if only one tire doesn't spin it probably doesn't have an lsd...not all trucks even sports and such came with lsds
Old Jul 23, 2007 | 09:35 AM
rtmorrisjr's Avatar
rtmorrisjr
You should also have a sticker in the glove box. for example, mine says 4.10 anti-spin. Also, another way to check, guys on here have done it, is to put one tire in the dirt and one on tar. Spin the tirs and see if you get a mark on the tar. another way to check (if not stickers) is to jack the rear of the truck up, and spin one tire. If you have posi one tire will spin one way and the other will spin the other...or it might be both same direction....now im confused, ill check on that and get back to ya.
Old Jul 23, 2007 | 06:52 PM
rhaines00ram
I got my build sheet and it says i have a 9.25LD rear axle 3.55 ratio .
What is the LD for ? locking diff maybee or light duty im not sure
Old Jul 23, 2007 | 08:56 PM
ryans590's Avatar
ryans590
ORIGINAL: rhaines00ram
if thats all it says then you dont have posi
LD = Light Duty
ORIGINAL: rtmorrisjr
if its open they will spin oppsit ways
posi same way
Old Jul 23, 2007 | 10:56 PM
spaz_22's Avatar
spaz_22
DJCS - Dana M44/216MM Front Axle
DMDP - 3.55 Axle Ratio
DRBP - Corporate 9.25 LD Rear Axle
DSA - Anti-Spin Differential Rear Axle
this is part of my build sheet. if it doesn't have the dsa after drbp...then it doesn't have a limited slip rear axle
Old Jul 24, 2007 | 05:57 PM
Dodgeboy328's Avatar
Dodgeboy328
I love the anti-spin rear end in my parents new hemi. It just makes things all that more interesting.[sm=gears.gif]
