Suspension tips?
Old Jul 23, 2007 | 11:31 PM
Briggsbud's Avatar
Briggsbud
Default Suspension tips?
hey my name is brandon. i have a dodge ram 1500. its got a 5 inch lift and the suspension is shot. i am looking at gettting a dual reservoir kit. from what i have heard it turns your ride to ****. if you have any experience or knowledge please help me decide. thank you for your time.
brandon briggs
Old Jul 24, 2007 | 12:39 AM
spaz_22's Avatar
spaz_22
Default RE: Suspension tips?
who makes the dual resiovor kit? is the dual resiover just dual resiover shocks? if it is, it shouldn't make you ride go to ****, if anything it should make it ride alot better, and last longer becuase it won't heat up as much becuase it has more fluid for the shocks to work with
Old Jul 24, 2007 | 12:55 AM
Briggsbud's Avatar
Briggsbud
im not sure its from a local shop. its got 2 shocks with the resiover on the sides. thats all i konw about them. they said that it would make my ride way too stiff.
Old Jul 24, 2007 | 12:59 AM
spaz_22's Avatar
spaz_22
are the shocks rated for a half ton truck? or made for your truck? see if there's a way to find out how much weight they are rated for.
Old Jul 24, 2007 | 01:03 AM
Briggsbud's Avatar
Briggsbud
ok i will. thank you.is there any way to adjust the shocks? what ones do you suggest?
Old Jul 24, 2007 | 01:09 AM
spaz_22's Avatar
spaz_22
that depends on the shock if they are adjustable. Some are, some aren't. Rancho 9000x are i believe adjustable. Some other ones are. Fox makes great shocks, but hella expensive. maybe you can post some pics of the shocks and or find out what kind they are and check out there website to findout more information on them. Just do some research and you'll be happy
Old Jul 24, 2007 | 01:16 AM
Briggsbud's Avatar
Briggsbud
yeah these things are 1500 installed for the front. alright ill look atthose brands. thanks man
