Low Beams Don't work
Old Jul 27, 2007 | 08:17 AM
98RamSport360's Avatar
98RamSport360
Member
Default Low Beams Don't work
So years ago I was driving my truck when I noticed that the low beam light were not on, I lift the tilt steering and they turn right on. So for the pass few years I did not use my tilt steering. Well my lack of interest in solving the problem snowballed and this is what I have to deal with now.
I was driving down the road again and I noticed my low beams are not working. So I drive home with my high beams on all the way. Sorry if I was driving behind anyone on here. I took it apart this morning to find that the wire came loose out of the connector. That would be an easy fix if the spark from the connection did not burn, melt and dry out the connector to the point that it was falling apart in my hand. So this morning I put on a two part epoxy, I am hoping that it will hold when I go to plug it back in. I will post my results later
Ray
Old Jul 27, 2007 | 08:20 AM
rtmorrisjr's Avatar
rtmorrisjr
Default RE: Low Beams Don't work
hope that solves the problem. good luck.
